| Posted by Gary on June 22, 2002 at 19:32:55: | |
| In response to Re: loose sink drain | |
I have this same problem on some pop-ups, there are some real crap parts for sale in these stores, a good quality pop-up will not do this,,,but, other then replacing it, you could always tie some twine around the end, or maybe bend the pivot rod with your pliers.
: : : : In my bathroom sink there is a standard ball into rod into upright piece setup, attached by a clevis. When I pull the plunger to stop the sink from draining, the clevis slides right off. When I've tried adjusting it tighter, the plunger won't move up and down. I guess my problem is that I can't seem to get it just right. It's either too loose or too tight. Is there any easier way to adjust this. ANy help is greatly appreciated. I've been at this for a few months and no solution.
