Re: loose sink drain
Posted by hj on June 21, 2002 at 01:42:48:
In response to Re: loose sink drain
From your description, it appears that the "U" shaped spring clip that attaches the clevis to the rod is missing, otherwise it would not slide off when you pull up on the rod.
: In my bathroom sink there is a standard ball into rod into upright piece setup, attached by a clevis. When I pull the plunger to stop the sink from draining, the clevis slides right off. When I've tried adjusting it tighter, the plunger won't move up and down. I guess my problem is that I can't seem to get it just right. It's either too loose or too tight. Is there any easier way to adjust this. ANy help is greatly appreciated. I've been at this for a few months and no solution.
Replies to this post
