Re: Sump Pump runs constantly
Posted by hj on June 19, 2002 at 08:51:55:
In response to Re: Sump Pump runs constantly
You have to check in the "hole". If there is water there, then the pump is either not pumping it out, or there is a continuous flow of water into the pit. If there is very little water in the pit, then the switch could have broken or is malfunctioning.
: We bought a 14 year old house last spring that has a sump pump. The sump pump normally only runs occaisionally, but today it started to run almost constantly. What could be the problem?
Replies to this post
There are none.
