| Posted by hj on June 17, 2002 at 23:07:25: | |
| In response to Re: My garbage disposal unit does not work. | |
The liquid plumber could have corroded the shaft so the disposer cannot start properly, the starting windings could have burned our or the starting switch stuck, There could be something stuck in it that you cannot see that is creating enough drag so the disposer cannot start by itself. These are a few of the possibilities. : My Garbage disposal unit stopped working all of a sudden. There is nothing stuck there. If I turn it on, I have to rotate it with a wooden spoon a couple of time before it starts working. I have to do that each time. Now a week or two earlier, I poured liquid plumber in the sink to clear a blockage. Does that have anything to do with it ? Any ideas ?
| There are none. |
