| Posted by Terry Love on June 16, 2002 at 21:45:40: | |
| In response to Re: leaky shower | |
![]() : If anyone can help me with this I'll be amazed. My tiled shower leaks at floor level below the door. I have replaced the pan, silicon caulked every imaginable crack, and aligned the sliding door so it hangs square.Finally I cleaned the groove in the drain where the weep holes drain to the drain pipe and placed a drain plug and acidized the weep holes. This seemed to stop it for a month or so. It started again and I saw that the drain was slow. I thought the water might be running back the other way through the weep holes and then over the pan so I used some liquid plumber and now the drain Jim,
| There are none. |
