| Posted by Scott on June 14, 2002 at 21:45:57: | |
| In response to Re: shower 3 stem replacement | |
![]() : I have a Gerber 3 stem shower. I was attempting to remove the hot water handle. I removed the screw and could not get the handle off. I did get it off, but broke the stem inside. Now I need to replace the stem. I have tried to get a stem socket wrench inside of the eschuteon pipe in order to remove the stem so that I can replace it. The smallest stem wrench is 21/32 and 27/32. The 27/32 will not fit inside the tube around the stem. The 21/32 is too small. Someone told me that the tube which is around the stem screws out or I should be able to pull it out. I have not been able to do this. I plan to replace the whole shower in a few months and will replace everything at that point. Now I just need to replace the stem so that I can control the hot water. : Thanks, : Kelly Kelly, Scott |
| There are none. |
