Amtrol RP10 Pressuriser turns on w/out demand
Posted by Charles on June 10, 2002 at 19:49:54:
My Amtrol water pressuriser turns on and off continously without demand. BUT it doesn't do it consistently (usually it's about 2 in the morning). From basic research it seems like the check valve is the most likely culprit. I turned on the pump and turned off the supply to the pump and the pressure did not change - I understand this is a test for a problem check valve. Could I fix this? Could you recommend someone who is familiar with these pumps (are you? - I live in seattle, capitol hill). Thanks
Replies to this post
