Re: high pitch noise
Posted by hj on June 07, 2002 at 09:16:59:
In response to Re: high pitch noise
No, because it could be caused by too many possibilities to try to list them all. And even then we might miss the one that applies to your situation. Call a plumber and see if he can duplicate the problem, or be lucky enough to be there when it happens. Being intermittant, it can be expensive to find if the cause is not immediately evident.
: once or twice a day for the last few months i get a high pitch noise(like a smoke alarm) If I open the domeatic h2o (either hot or cold it goes away after 10 seconds. I have my own well and baseboard hot water heat. hot water via a tank coil. Any ideas?
Replies to this post
There are none.
