| Posted by hj on June 07, 2002 at 09:07:45: | |
| In response to Re: PVC Leak - HELP!! | |
One truism of the plumbing industry is that it is almost impossible to cut out just enough pipe to put a fitting in and not have it leak, whether it happens immediately or a few years down the road. The fitting is designed for the pipe to go all the way into the recess. You have to cut it out and make a proper insertion. : Hi! : I just got finished replacing the drain on my shower stall. It was a big job 'cause I had to rip the 1st floor cieling apart to do it. Now my problem is the the 2" sc40 connector where I tapped into the line is leaking. I'm not sure what the heck happened. I cleaned good prior to cementing, yada, yada. The problem is there would only about 1/2" of pipe left after I cut out the drain again to glue another connector to. My question (finally, sorry) - do you have to insert the pipe fully into the connector (~1") to get a good seal? Or is there an appropriate glue or sealer I can use to fix the leaky connector? Thanks for the help and sorry for the long post. : Jack
| There are none. |
