Re: Just replaced water heater
Posted by Gary Swart on June 05, 2002 at 15:54:30:
In response to Re: Just replaced water heater
It sounds like you did everything right. Actually, there are very few places to screw up. If you had wires reversed, hot/cold reversed, or a joint cross threaded or not tight, those error would show up immediately. If you are leaving for an extended period of time, you could shut off the electricity to save some power, and you could turn off the water just to be extra sure, but I really don't think there is anything to worry about as far as your installation is concerned. You might be well advised to turn off your washer valves, I have a friend whose house was extensively damage from a broken washer hose while he was on vacation.
Replies to this post
There are none.
