| Posted by hj on June 04, 2002 at 01:10:01: | |
| In response to Re: Cast Iron Hub Fitting with 3.12 ID Hub | |
Are you sure you were not using 1 1/2" pipe? There is no way a 2" coupling would fit into a 2" hub, much less a "donut". : : Without being there it is impossible to tell if things are just not fitting together properly. But it is possible that they won't since the lead hub was never designed to have the "donut" installed in it, so it could have the wrong dimensions. : : : : Matt, : : : : I was finally able to get the donut seal to work by placing a 2" coupler on the end of the pipe. The larger OD made the seal work properly. Thanks for the help and the great site.
