Caroma Caravelle 305, dual flush
Posted by Kevin on June 03, 2002 at 01:48:03:
This toilet has a half flush and a full flush. I was having trouble with the half flush. It would not clear liquid waste (it is intended for liquid waste only). I contactd the company for help and their advice made it better, although not perfect. You may want to think twice about buying this toilet. If you're having the same problem, here is the advice I got. Take off the tank lid. There is a hole in the middle of each button. Take a philips head screwdriver and loosen the screw, which is visible in the hole. As you loosen the screw, the flushing mechanism will rise. This will give you more water per flush. I hope this is useful. Kevin
Replies to this post
There are none. |
