| Posted by hj on June 02, 2002 at 09:06:59: | |
| In response to Re: Cast Iron Hub Fitting with 3.12 ID Hub | |
You may not be describing the problem correctly. The o.d. of the pipe should be about 2.375 If the "donut", and hub, were only 2.75 that would create an annular ring that would have been too small to make a lead/oakum joint, and 3/16" of an inch would make a very thin donut. 3.14 is about the correct dimension for a 2" caulk joint hub. The "donut" has to snap into the hub so that the pipe will expand it slightly and seal to the cast iron. : : My problem began after I removed a section of 2 inch galvanized drain pipe from a cast iron fitting (which is set in concrete in my basement floor). The joint was originally sealed with lead and oakum. When I went to install a new section of ABS pipe with a Fernco 2x2 donut seal I found out that the ID of the hub was to big. It has an ID of 3.12 inches instead of about 2.75 inches which it looks like seal would need to have a tight fit. My question is whether or not there are seals available for a hub with an ID of 3.12 inches? or will I have to re-do the seal with lead and oakum? Note the house was built in 1941. : Matt,
| There are none. |
