Re: freezeproof pipe
Posted by Gary Swart on June 02, 2002 at 00:50:16:
In response to Re: freezeproof pipe
Never heard of freeze proof pipe. Doubt if it exists. What I's do is bury Type K copper as deep as possible. I'd make the outlet end slope back to the house and put a tee on the end. Connect the water supply with a valve into one side of the tee. On the other side, put another valve connected to a drain. In cold weather, shut the supply valve off and open the drain valve. Open the faucet also. The line will drain and not freeze. Y
Surely you don't need water on the deck during the winter. Even if there is some kind of freeze proof pipe, the faucet won't be.
Replies to this post
There are none.
