Re: Painting behind the toilet
Posted by Gary Swart on May 29, 2002 at 16:14:54:
In response to Re: Painting behind the toilet
The way I handle the problem is to use some plastic to keep the paint off of the toilet then just get a brush in as far as possible. You won't get the whole wall for sure, but for anyone to see what wasn't painted would require them to perform an unnatural act! Of course removing the toilet would work, and isn't a bad job unless you run into corroded bolts. You'd be wise to replace the wax ring just to be sure. I perfer the new waxless rings, but your choice.
Replies to this post
There are none. |
