Re: sewage back up in remodeled bathroom
Posted by Gary Swart on May 27, 2002 at 10:54:12:
In response to Re: sewage back up in remodeled bathroom
You're probably going to have to afford a plumber. Your main drain line is plugged. Liquid drain openers are OK for soap and hair build-up in an individual drain, but when there is blockage in the main line, you have to have it snaked. If you have access to a manuel snake, you could try it yourself, but it's most likely a job for a pro with a power snake.
Replies to this post
There are none.
