washing machine drainpipe
Posted by Terry on May 25, 2002 at 01:06:24:
In response to washing machine drainpipe
The washing machine is located in the basement. The washing machine empties it's water into a tub, which in turn empties directly into the basement floor drain. I have to tare up the floor in the basement to replace the P trap at the floor drain, so in addition to replacing the trap, is it possible to tap into the existing drain pipe under the basement floor and run an additional pipe under the floor towards the block wall behind the washing machine. When the pipe reaches the wall add a P trap and then run it vertical (90�) but parallel to the block wall.
Replies to this post
There are none. |
