| Posted by hj on May 18, 2002 at 09:25:28: | |
| In response to Re: Using Flexible 1/2 copper | |
The proper way is to install the wall, anchor the new valve in position, and then pipe the water to it. Getting the pipes to line up correctly is why they make several different types of fittings. Do not try to bend any hard copper, it will kink on you. : I'm refinishing my hall bathroom, and I'm now ready to put the tub in. I finished soldering my water supply lines up to each shutoff valve, which are approx. nine inches up from floor. Now I need to continue from the shutoffs up to the shower assembly. : I'm a little nervous about whether my connections leading up to the shower assembly will exactly fit. To avoid any potential problem, could I use the FLEXIBLE COPPER TUBING? If they are slightly off, I don't feel bending "L" copper is a good idea (unless I have pipe bender (how much are they??)). I may have some maneuverability, but is it ok to use flex copper?
| There are none. |
