Re: Moving garbage disposal
Posted by hj on May 18, 2002 at 09:17:30:
In response to Re: Moving garbage disposal
Two things could complicate moving it. First if it is fairly old, it is sometimes difficult or impossible to get it reassembled, and if the drain is in a bad spot it can make reconnecting the trap very difficult. If neither of these apply then it is a fairly easy thing to do. You just might want to have a plumber do it. If you DIY, you might have to make several trips to the hardware store before you get the job done.
: Is it possible to do this? And move it to the other side of a double sink? And can it be done easily by someone who doesn't know anything about plumbing? If so how? Without causing damage. If not about how much should I pay someone to do this for me?
: Thanks
: Lisa
Replies to this post
