| Posted by Gary Swart on May 18, 2002 at 03:15:20: | |
| In response to Re: Using Flexible 1/2 copper | |
I'd run the solid copper up to approximate the right heighth, then use flexible lines to bridge from the cut off valves to the fixture. I do the same with basins, sinks, and toilets. Heck of a lot easier to connect and disconnect, you don't have to get to finite with the rough-in and you don't have to bend anything. |
