Re: washing machine in my basement venting
Posted by Gary Swart on May 15, 2002 at 20:38:02:
In response to Re: washing machine in my basement venting
You must have a P-Trap or you will have sewer gas coming through the drain. The washer should not be plumbed solidly to the drain. Washer drain hoses have a crook in their outlet ends. This should just hang into the top of a 2" vertical drain pipe that extends above the level of the water in the washer to prevent siphoning. The washer's pump will expel the water up and into the drain, and then the P-Trap is usually located close to the floor, just before it enters the main drin.
Replies to this post
There are none.
