Re: some drains got clogged
Posted by ClogCleaner on May 12, 2002 at 21:47:31:
In response to Re: some drains got clogged
$60.00 per drain is TOOOOOOOOOOOO much!!!!...You will need yur main sewer-line cleaned out and that may take care of your "WHOLE" problem. Now you may need to plunge a few drains after the cleaning thats all. We charge $60-$80.00 to clean a sewer line, and if a second or third drain needs to be unstopped, we charge an additional $20.00 per drain. Most likely yopur problem is with your sewer line.
Replies to this post
There are none. |
