| Posted by hj on May 12, 2002 at 11:19:54: | |
| In response to Re: Pressure Balance Valve | |
There are several companies that make them. That one should fulfil the requirement. : I'm remodeling my bathroom, and want to use one of those antique '2 handle' exposed shower fittings with the rose head. : My plumber is nervous, telling me that code requires a pressure balanced valve. My research has located an in-line pressure balance valve (called Tempera at www.pppinc.com). Could I use this to provide the same function? Or would this still be in violation of code? I live in Southern California, if that matters. : Thanks in advance! : Richard Blackburn
