| Posted by Kirk Ellis on May 10, 2002 at 20:22:47: | |
How about if I install shut-off valves below the tub where I can access them through the apron, and run the 3/4 pipe 3 feet from both those shut-off valves to the Grohe thermostatic valve ? The Grohe valves and trim will be mounted in the wall at about 45 inches height. The spout will actually be a Kohler Laminar Flow Ceiling Mount K-923 -- it looks really unusual and leaves me a clear tub deck :D On the mini-arrestor issue, where should they go ?
