Re: Leaking Redundant outlet pipes on immersion heater tank
Posted by Gary Swart on May 10, 2002 at 18:34:33:
In response to Re: Leaking Redundant outlet pipes on immersion heater tank
I think you're on the right track with solder, but I wonder if you used flux? Without flux, 5 lbs of solder won't make a joint. Try cleaning the joint with emery cloth or sand paper first, then heat the joint a little. When the joint is fairly hot, put some flux on it, then apply more heat and try the new solder again.
Replies to this post
There are none. |
