Re: Can I Modify Tub Drain / Overflow Assembly?
Posted by Dan on May 10, 2002 at 09:02:24:
In response to Re: Can I Modify Tub Drain / Overflow Assembly?
: You can't "add a link" that will make 45's but you can switch out that type of stopper to a lift and turn type installed into the tub shoe.
: IMHO Whirlpool tubs should use a cable drive waste and overflow. Most people don't like the lift and turn sticking up, and the traditional linkage get a little long on larger tubs causing you to fiddle with it for a good seal.
THANKS for the info. What is a "cable drive" type of waste/overflow?
Replies to this post
