| Posted by RJ on May 08, 2002 at 07:01:24: | |
| In response to Re: Sewer Replacement | |
: WE have a forty year old house on a slab (with cast iron sewer lines under the slab and clay lines outside the foundation)and we have some tree roots. We have had the line vidoed and there is NO collapse, but there are several seams where roots have come in. One joint has moved slightly out of line. I don't know if the line has ever been cleaned, but we had only one blockage in the last ten years. : Since there is not clean out plug, the plumbing company suggests replacement with PVC (which would include a cleanout plug) : MY question is whether this situation requires replacement or would yearly cleaning (even with 3" inch brush in 4" sewer line) and rootx treatment keep the problem under control? : thanks....cspinks I would clean it and then Rootx it immediately. Then Rootx once a year without the cleaning. That should do the job. Its certainly the least expensive and invasive, if in the future this method proves to have failed you can always replace the line. |
| There are none. |
