| Posted by Kirk Ellis on May 06, 2002 at 20:43:13: | |
| In response to Re: Cutting into existing drains for leak test | |
When I install which line ? They say I need to be able to plug up the line over in the existing drains -- maybe ten feet horizontally downstream from anything I was planning on touching. : There is a fitting for the testing that you put in to the line when you install it.
| There are none. |
