hot water pipe leaking
Posted by richard.payne on May 04, 2002 at 04:22:46:
Hi. The pipe /pvc that leads away from the hot water tank goes directly into the cement floor. Guess where it is leaking, big time? Right where it enters into the cement floor. Must I (horrors) dig up the cement floor to find (as the Ace Hardware man said) an elbow connection? At that point I was advise to remove all the rusty piping and hook up new piping that will leads back to the hot water tank. Or should I literally tear up the cement floor and follow the routing of the pipe - and replace everything? More importantly, what if I don't find this so-called elbow? Thank you.
Replies to this post
