| Posted by PaulW on May 02, 2002 at 15:34:36: | |
| In response to Re: slab leak? | |
Sounds like you possibly have a supply line leak not a waste water problem. If you have city water check the water meter for usage when everything is shut off, if on well water check your pressure gauge for a drop or the pump for cycling. If you have inslab heat that also could be a source. Ether way don't put off having a plumber look at it. : We have water coming out from under the shower encasement onto the bathroom floor as well as outside the house foundation. It is a one story dwelling, and the shower is on the outside wall. How do I know what the problem is? The shower has not backed up at all.
| There are none. |
