repair Mansfield frostproof sillcock, installed 1972-75
Posted by Raymond Coullard on May 01, 2002 at 15:12:32:
Sillcock leaks, want to repair it. Removed handle center screw but blue plastic handle will not come off. The handle appears to have a nut or something else inside it prohibiting it from coming off. Should I be able to turn the handle in a counterclockwise direction and remove the handle? Then I should be able to get to the packing and stem/seat. Pls. advise. Thanks. Ray
Replies to this post
