Re: Clay Tile to PVC or DWV
Posted by hj on April 29, 2002 at 23:01:09:
In response to Re: Clay Tile to PVC or DWV
There is nothing that would slip into a clay pipe and make a water tight seal, even if it could be done without creating an obstuction to smooth flow. : I am looking to connect a 4inch Clay tile pipe to a 4inch PVC or DWV pipe. I have used theoutside diameter to outside diameter connectors in : the past to connect a clay tile to DWV piping. However, this situation is different in that I have no access to the outside diameter of the clay tile : as it is embedded in a concrete wall and flush with it. Therefore, I need some kind of adapter that can go from the inside diameter of a 4 inch clay : tile to the outside ( or inside ) diameter of 4inch PVC or DWV piping. I there an adapter available that would do this for me. Or is there another alternative. : : Thank you, : Eric W. Zachmann
Replies to this post
There are none. |
