| Posted by hj on April 29, 2002 at 22:58:15: | |
| In response to Re: clearance for toilet | |
You need as much room as it takes to get your arm to the bottom of the tank, or as much as it takes to get the fill valve out of the tank, whichever is larger. : I would like to make a banjo style countertop extending over the toilet. No one seems to know how much clearance is required between the top of the toilet and the underneath part of the granite countertop that would allow access to the tank without disconnecting the whole toilet. Being granite, it would not be possilbe to hinge it. The toilet is a Toto one piece. Thank you.
| There are none. |
