| Posted by Gary Bugai on April 29, 2002 at 10:43:43: | |
I have a shower pan with a drain set-up.Rather then glueing it to abs plastic pipe, it is design to slide over it and is sealed by a rubber ring. I am not sure of the directions- says to then place on plastic ring and press on with chaulking iron or large pipe nipple. Cut excess pipe with internal pipe cutter. Any advice? Does this type of set-up last, am concern that it might leak. |
| There are none. |
