| Posted by More on April 28, 2002 at 22:56:31: | |
| In response to Re: BLEECH STAINS See Ann Landers | |
It depends upon what surface is stained and if the Bleach burned the surface below that. The Bleach is a chemical reaction which removed the color pigment of the material that is stained. Your skin has a ph of 5.5 to 6.5 and neutral ph is 7 and you need to know the ph of the Bleach which is much more corrosive such as a ph of 9 (or at least an approximation) to get the area neutral first. Then the stained area which has been removed of pigment needs to be gradually repigmented. Go to the library and research Ann Landers columns this topic comes up about once each quarter. : HOW DO IGET RID OF BLEECH STAINS
| There are none. |
