Re: Rear Toilet Connection?
Posted by hj on April 28, 2002 at 18:58:14:
In response to Re: Rear Toilet Connection?
Almos all manufacturers make a floor mounted rear outlet toilet. There are also a few companies that still make residential wall mount toilets with rear outlets, although these are much more expensive to install because of the wall carier fitting.
: I'm from England where most toilets are connected through the rear by a 4" connector. I have a need for a toilet of this design as I want the pipe to go through a wall to the stack behind. I do not want ot dig up the concrete floor just to install the toilet. In the USA, it appears that all the toilets are joined to a pipe located in the floor. Is this code or just good marketing? Do you know of a toilet which has rear connectors?
: Thanks
: Rich
Replies to this post
