Re: Need help with Kohler Rialto Pressure lite toilet
Posted by More on April 27, 2002 at 15:19:47:
In response to Re: Need help with Kohler Rialto Pressure lite toilet
The valve head is in the flush valve cartridge in the piston assembly. The assembly has a spring loaded regulator in it. If you are going to try this repair yourself, make good and sure you don't lose the tiny screws that hold the piston assembly down. AND count the number of quarter turns as you remove the assembly cap. Have you considered going to Kohler's web site and reading the self help FAQ's? Why are you looking to get to the valve head if the screeching has stopped? Don't worry about it now - the valve has passed the sand into the toilet bowl and out of your life.: More, thanks for your help. I still have a couple of questions. Where is the valve head? I am attaching a picture of the toilet diagram and the unit if that helps any. : Thanks again,: Tanya
Replies to this post
There are none. |
