| Posted by hj on April 25, 2002 at 22:05:40: | |
| In response to Re: Reliance 501 Hot water heater problems | |
The main problem is probably one or both elements have burned out. You could also not have hot water because the circuit breaker or high limit switch has tripped. But either of these would normally be a symptom of the other problem. : My Reliance 501 40 gal. hot water heater was working yesterday and know it is not. I have a feeling that it is one of the elements. Is there a way to check to make sure that is what it is? Also where can I find a wiring diagram for the unit?
| There are none. |
