Re: BASEMENT SHOWER DRAIN OFF CENTER
Posted by Gary Swart on April 25, 2002 at 15:37:10:
In response to Re: BASEMENT SHOWER DRAIN OFF CENTER
You'd better break out the concrete so as to access the drain below the floor level. There is a Pee Trap under there, and you can come from there to the new shower as long as there is a slope from the shower to the drain. If you try to do this above grade, you would have to raise the stall. This would be more work than breaking concrete. Rent a small rotary hammer and break the hole you need.
Replies to this post
There are none. |
