Removing tub to repair leak
Posted by Jonathan Lyerly on April 23, 2002 at 20:49:21:
I have water leaking from underneath a fiberglass tub unit. I suspect that the water supply lines are leaking. Since the lines are inaccessable from below, I will probably have to remove the unit. I would appreciate any tips on doing so. This is a fiberglass unit, installed with walls on 3 sides and a skirt facing out. The drain is in the back center. The faucets come up through the tub ledge(rim). The supply lines are flexible tubing (quest?). I will need to disconnect the faucet supply lines and drain from above before removing the unit. Thanks
