Re: removal of vanity sink and disconnecting water supply
Posted by Gary Swart on April 21, 2002 at 21:55:25:
In response to Re: removal of vanity sink and disconnecting water supply
The drain can be capped with a screw-on cap. The pipes are another matter. I'll assume you have copper pipes. It's no problem to cut the pipes, a hacksaw or pipe cutter will do that, but capping is another problem. There needs to be a cap soldered on the line ends. That's not a high tech job, but one does need a torch,flux, and solder. However, give those basics, soldering is not difficult and there are plenty of adaquate instructions with torches. It would cost less to buy a torch, flux, and solder than to hire a plumber to do it.
Replies to this post
