| Posted by hj on April 21, 2002 at 10:35:53: | |
| In response to Re: Toilet Flange not level | |
The pipe coming through the floor was installed crooked, so the flange is also not level. That is not a problem as long as the toilet does not touch the high side of the flange when it is installed. The corroded flange can be a problem since it has weakened and could break when you refasten the toilet to it. Replacing the flange can range from a simple installation of a repair ring to cutting off the old riser/elbow and installing a new one. How complex it is depends on your actual situation and your abilities if you try to fix it yourself. : And of course the wax seal broke and the subfloor is rotted. Is it possible that a leak occured, rotted the wood, then the toilet tilted which in turn tilted the flange? : 1) The flange is very corroded on top. Do I need to replace it? How? : 2)Can I modify the subfloor level in the bowl area to match the flange tilt? : Thanks a lot for your help.
| There are none. |
