| Posted by joe on April 19, 2002 at 00:03:07: | |
| In response to Re: antique pedistal sink installation | |
: : what is the best (only?) way to support a large pedistal sink? it will be against the wall. i do not see any holes for support fittings, just the hole down the center of the pedistal and a cutout for the pipes. : : advice would be appreciated as soon as possible. : : thanks. : ok so further searching took me to the two holes behind the actual sink. what i'd like to know is what is the bolting hardware (bolting hardware?) called and/orwhere to purchase it. thanks. Having just installed one, you need what are called hanger bolts. They are threaded on both ends...probably need 3/8*. You need something in the wall (1x6) to attached them to. |
| There are none. |
