| Posted by hj on April 14, 2002 at 09:45:08: | |
| In response to Re: Gas pipe size | |
Your building department will tell you the size when you apply for the permit to install the pipe. More important, possibly than the size, is what type of pipe you are going to install and whether it will be buried or above ground the whole way. Again, the building department will approve this also. : I want to install a gas pipe from gas meter to the pool filter room which is approx. 65 ft. I'm going to install a 400,000 btu heater for my inground pool. What size pipe is legal and appropriate to supply the proper amount of gas to the heater and can I route the pipe outside along a garage wall and outside fence to the filter room. : Thank You
| There are none. |
