| Posted by Gary Swart on April 12, 2002 at 21:28:57: | |
| In response to Re: drain in landry room backing up | |
Most likely the drainline between the washer and the main sewer line is clogged. It could be in the pee trap or elsewhere in the line. I'd get a snake, you can rent one at most any rental store, and run that through the line from the washer end. |
