Re: water pressure
Posted by Gary Swart on April 12, 2002 at 11:27:27:
In response to Re: water pressure
The pressure will be the same as the house (if it's on the same source) The question is how much volume will you get. If the supply line is small, you will not have the volume as if the line was large. Compare the area of a circle with a 1" diameter to one with 3/4" diameter. Remember the old HS math? Area = [Pi x (radius squared)]
Replies to this post
There are none.
