Re: Installing a new washer machine
Posted by Gary Swart on April 11, 2002 at 00:36:09:
In response to Re: Installing a new washer machine
There are a couple of important bits of information you didn't include that are pretty vital to determine the complexity of the job. 1. Where's the drain and 2 where is the water supply in the new location? Then of course, how handy are you with tools? It's not brain surgery by any means, but if you have to install new water lines and tap into the drain, it does require a few tools and a reasonable amount of sauve in their use. I surmise by the wording of your question, that you are not a big DIYer, so a plumber might be the best way to go for you.
Replies to this post
There are none. |
