| Posted by Doug Freitag on April 10, 2002 at 12:35:42: | |
| In response to Re: Leaking main | |
: Dear Sir, : The main valve which controlls the water supply to the house is leaking.What could be the possible reason/s and what is/are the solution/s. : Thank you, : Rejeanne Ramtahal Where is it leaking? On the stem? Write me for help. It may be a very simple fix. If it's the stem, turn the nut below the valve's handle clockwise about 1/4 turn with an adjustable wrench. That will tighten the packing and cure the problem. |
| There are none. |
