Re: Semi clogged 1.6 toilet
Posted by ClogCleaner on April 08, 2002 at 00:14:26:
In response to Re: Semi clogged 1.6 toilet
You need to call a Professional Drain Cleaner to tackle that problem. If you were in my area I would charge you $50.00 if i could unstop it with my plunger or auger. Toilet may need to be taken up and taken outside, turned upside down and backwashed to remove obstruction from toilet. If you don't retrieve anything from toilet, I would power auger the hole with my mighty Spartan 300 drain machine.Of course if we have to pull the commode and all that we would charge an extra $20.00.....good-luck.
Replies to this post
There are none. |
