Re: Union Brass Shower Diverter
Posted by hj on April 06, 2002 at 11:27:34:
In response to Re: Union Brass Shower Diverter
It is possible that tapping it in damaged the "O" ring, but without being there it is impossible to tell if there is some other problem which is causing your symptoms.
: It is an exact match to what I took out of the wall....but I suppose there is the possibility that the old part wasn't the right one. The only place that the fit was tight was at the o-ring, so I helped it along by tapping it in. The diverter doesn't have a washer and screw on the end, but is a cylindical cast piece with a hole in it, then an o-ring, then a shaft and a big nut, then a sleeve. So please tell me that its supposed to fit real tight.
: I don't know for sure what make the faucet is but the parts I can see are stamped Union Brass.
Replies to this post
There are none.
